Hi all
New to this site I’m just about to venture on my first build I’m am thinking jet powered also what size boards would you recommend
Not strong enough.
Greetings Frank
I looked at those as well. The jet drive in the picture is a 2600 watt model. That same company also sells a 6000 watt model…KED380T. No one here has tried putting one of these on an efoil. There’s no way a 2600w jet will work. You might have a shot with the 6000w unit, but it would be an experiment.
Correction…2800w…not enough
