Try to log your erpm to see where you are
Load increases to a point where erpm will not raise much more and amps will raise to much
Erpm is calculated on pair of poles not poles , check this …
Better to change one value at the time and see what it does , limiting erpm will limit load and amp as well , but one limit is enough I think
Unfortunately I have no means of logging. Just amp meter and remote with screen. I bought flipsky bluetooth module but cannot connect it together with VX2 receiver at the same time into FSESC and I think spending money on metr.at is a bit too much for extent of my project
I was counting max erpm limit according to vesc tool guidelines, 12 magnets, 6 pole pairs times 10.000 should be max erpm which is what I set (60.000).
I was thinking about 3 blade prop just have to wait till it will get printed for me.
As for seating a bit in the front - I was also thinking about that but that should not influence how much max current I can draw.
Anyway I flashed new fw 5.1 with no HW limit even though I am not reaching anywhere near 120A just to see and left default erpm limit.
I don’t use the vx2 , but normally you connect the receiver to the vesc via the uart cable and the get the data on remote screen , not need of the BT module in the case , for real time values
( vesc needs to be set on uart , set up should be around on net )
And I think you can free the uart port of the vesc using the receiver non vesc for this remote ( spare part ) classic way using ppm cable
Ok, now I understand what you mean. I am getting all available data on my VX2 - speed (from pole pairs), current and graphically remaining battery capacity. There is nothing more available. I think only maytech V2 gives RPM and other stuff.
So only getting non-vesc receiver, plugging it to ppm port and using bluetooth in uart port seems to be the only way how to do some data logging.
Yes , but speed display is based on erpm , nb of teeth and wheel size , so by putting a ratio of 1 , you can managed to get rpm , or at least a number that can make sense
Or you do a ratio : knowing top speed off load ( in this air) and in the water on load ( should achieved around 70-80%)
That is how I have it set up - ratio 1 (direct drive), 6 pole pairs and I am getting 10 km/h speed on display / checked by phone GPS and speed is identical.
So do you think that size/pitch of prop is the only limitation now to get me to higher speed/amp draw?
I am currently using the original Pacificmeister drive on a fixed SUP board (actually a “Windsurfer” board from 1979… ) and from my experience you will need a prop of at least 120mm diameter (maybe even more for a inflateable) in order to get on plane which will be needed to go over your current ~12kmh displacement-speed.
I am currently getting up to 30km/h @140Amps - not sustainable of course; sustainable is ~20-25km/h at 60Amps.
One thing I found helpful is to reinforce the 3D-printed prop with Glasfiber in order to reduce deflection during acceleration.
To have something that lasts, I would recommend to go with the 65151 Motor and either a Flier or Flipsky ESC with at least 200A - of course, this will not fly with your 500USD budget limit…
Nice
Numbers fits
46v x 0,95 duty ( because you don’t have 100% with vesc ) x 49x 3,14 x 100 kv x 60( min to hours )
/ 1000 000 ( mm to km ) = 40,34 km/h
For the 49 mm it is my guess ( according to log on metr already done on some post ) regarding pitch of this prop
So your speed is matching the erpm of your motor in theory
Water test : speed should because off the load , be around 70-90%
If you get speed close to 35km/h on remote by around 13km/h in gps , it means that the motor takes its rpm but the prop slip is to high and probably under cavitation … for exemple
If you get 20 on remote and 13 gps full throttle : this means the rpm drop is too high , prop too big and amp should go high also …if not your motor can be dysynchronized under load , you can correct this in vesc tool under stator saturation …
Try to put 80a max for the motor and 70a for the battery ( since the motor amp is always a bit higher than batt amp )
And your max erpm off load on 50v is 35000 so 60000 isn’t limiting
My guess : prop cavitation , to much load for the blade area ( but I am not a engineer …)
I can understand that if there is big disproportion between speed on remote and on GPS … there should be some cavitation playing role.
But my present problem is that there is identical speed on both and it is low and amp draw is low. I could imagine that there is too high amp draw and slow speed - too big or too steep prop. V_S made this prop for use with 63xx motor a he says that it is his most efficient prop.
Seem the only thing now to try (not having another prop) is to up stator saturation in vesc tool. What setting would you recommend? 5% or 10%?
I got reply from @V_S [quote=“V_S, post:9, topic:8489, full:true”]
watching your video, i guess your prop is pulling Air. Thats the reason, it has not enough thrust and doesnt pull much Amps. ( freespinning in Air!?)
A bigger prop wouldn help
[/quote]
