I need to replace stock bearings on my 6384 motor (6800 and 6900) to stainless or ceramic, but not sure what and where to by from. There are some german webshops with plenty models in stock, but shipping and fees will be about €40 to my country so are looking for options on Aliexpress or Ebay, which means mainly chinese bearings. I would prefer ceramic which are priced from €3-10 on Ali. The problem is I don’t know the quality and if they are worth buying. I have tried googling the different names found on Ali, but can’t find any info/reviews about chinese ceramic bearings, so if any of you forum members have tried Ali ceramic bearings, it would be nice if you could share experience with them and what brands (links?) to go for.
I had the same problem, although shipping was „only“ €16.9. Got these for my 63100: Edelstahl Dünnringlager SS-6800 >> Bestellen Sie heute!, 4,08 €
They work well and play is OK.
I could not find stainless ones on ali, but I tried these hybrid ones:
US $28.52 8% Off | 10Pcs S6800-2RS 10x19x5 mm ABEC-7 Stainless Steel hybrid Si3n4 ceramic bearing 6800RS 6800 2RS Without Grease Fast Turning
https://a.aliexpress.com/_mLFYq3o
They work but I prefer the stainless steel ones, they have less play.
Order some spare ones, you need to change them once in while.
I have ordered from Kugel-express before when they shipped with normal Mail, but now they use only DHL €25 which also triggers some VAT fees, so I rather spend the money on some “quality” china bearings instead
Regarding hybrid bearings I saw a video from a cyclist who warned against it because the balls being harder was wearing out the races causing play, so for me I only go full ceramic ZrO2 which should last long time, or stainless and replace once a season or so. The challenge is finding the right quality for the task.
Do you know how these stand up against salt water? I run stainless bearings too but my use is almost always in sweet water.
Normally I use them in fresh water but for the last two weeks I used them in the mediterranean (more salty than the baltic sea). So I’ll see soon, until now, they work OK.
Took the motor apart for maintenance today. The bearings can withstand salt water quite well, rust wise they look OK. However, I changed them too late, especially the two bearings at the end of the bell were totally worn. One fell apart when removing the bell, the last one when trying to remove it. They had about 800km on their spheres, to many for the load I put on them. I think they should be changed after 300-500 kms.
you’d better find out who is the real original manufacturer of this 6384 motor, and ask for bearing replacement, otherwise you will have to undertake trial and error many times before find the right one to lucky.
No? It’s marked as a 6800 bearing so he orders a 6800
It is a Saite 63100 motor and it needs 3 6800 bearings 19x10x5, I use these stainless steel ones, they need to be changed every now and then, you hear and feel it when it’s time: Edelstahl Dünnringlager SS-6800 >> Bestellen Sie heute!, 4,08 €
No need to contact anyone apart from buying the bearings, I know they work after aprox. 1500km on this motor.
