I just received my Swordfish X 300A ESC from Alien. When I turn it on it beeps 3 times with the last beep being a slightly lower tone than the first two beeps.
I have it attached to a 40V battery.
My problem is that it is not providing any power to the receiver. When I check for power on the cables there is zero volts at the end of the wire. I believe that Brown is negative, Red is positive and Orange is signal, but I checked all 3 wires and got no power in any combination.
I looked at the configuration software and didn’t see anything in there about enabling power to it.
I also tried giving external power to the receiver such that only GND and signal were going into the device. I couldn’t get it to move.
If you are familiar with these ESC’s please let me know what you think.
Ok, that explains it - I got it working with the external 5v to the receiver. Probably the first time there was something about my remote that locked it out.
@Manu, yes, I’m pretty sure there’s some kind of magic pipeline between China and the US. Things that I order from Amazon arrive directly from China within a week.
