Takuma motor conversion
Hello everyone! I bought a broken Takuma for a really good price, with 2 batteries. Everything seems to be working fine except the motor. I’m wondering if anyone replace the motor with a direct drive Flipsky? What do you think will will be the best option with the original ESC/battery pack?
I’m thinking about the 65111 maybe? or 6374…. the battery is rated for 48v/35amp.
Don’t know the max discharge current on this battery/esc.
Thank you!
Hello, your battery BMS is set to 100amp max, go for a 65161.
wow thank you very much for the really fast answer! That’s great, I already have one. :blush:
Ok, I tried to connect the motor, it’s spinning fine at low load, but when I try to go higher it’s start shuddering and stay at low rpm. I’ve seen a post in the forum about it, but never get the end and how to fix this issue.
Don’t know if the Takuma ESC is compatible with this motor, or even if this can cause this issue.
I do have a Flipsky ESC but it’s liquid cooled, and this board have an aluminium plate style cooling, so can’t really put it.
Imean I can to try but can’t use it for a long period. But if I can I want to keep the Takuma ESC.
If I have to change it, I think the Mini V6.8 will work fine for this type of cooling.
Hello, I have a takuma also, can you share the photos of your motor installed?
