Any pros/contras from your side welcome
I like the shape compared to a windsurfboard and with a thickness of 15cm it offers more space.
A completly build up of a board from zero I would exclude for first build of an efoil.
If you want a cheaper option, Kite slalom boards make good conversions. I have done 3 boards like that. Got each for ±£150. They are sometimes around 10cm thick. If you want thicker though then you going to need a wingfoil board or sup foil board.
The thickness of that Takuma doesnt account for the concaves, so you need to be careful how much thickness you really have to play with.
I also like the form of the takuma boards, unfortunately these boards offered by decathlon have at least 5’6.
And if you check they are made from glassfiber, not carbon!
I’ve transformed 3 wingfoil boards of 5’0 into efoils. Definitely wouldn’t go much bigger than 5’2. My last transformation was Gong Kube 3’11 which is a perfect size for efoil.
And since it’s your lucky day there is is a full carbon version of that takuma available for 590€. It’s not as thick with approx 12cm, but will be enough for housing your battery, electronics etc…
Yes, GFK I have seen. Not as much stiff as CFK but should also work.
I have 90kg „on board“. So I thought the 100ltr 5.8“ is better then a smaller one.
I saw your builds. Great work and thank you for your good build description!
I have also 90kg, and you’re right, the size of the board matters more than the liters volume. Its all about getting the board started. And in my opinion it gets very tricky to start a board smaller than 120cm. On the other hand i think the board doesn’t need to be bigger than 150cm, because you will quickly progress and want a smaller board to be more maneuverable.
