Teensy 4.0 GPS Dashboard / Remote Control / still under development
Hi everyone,
After 1.5 years of development, it is finally time to share the first pictures of my custom remote control.
This is a wired remote. I have developed wireless versions in the past, but was never truly happy with them due to screen refresh times, water-induced signal degradation, and interference. For use on an electric jetsurf board, a wired version simply makes the most sense.
Here is why:
  • Physical Control: A wired connection gives you something to pull against, providing much better stability and control while riding.
  • Real-Time Data: True real-time telemetry with a screen refresh rate of 100 Hz.
  • Loss Prevention: If you wipe out or jump into the water, the remote stays securely with the board.
  • Future-Proof Flexibility: Highly adaptable to hardware upgrades. You can easily swap in a cheap $20 GPS module or a high-end one with faster update speeds and advanced logging.
  • Zero EMI: Electrical noise is a massive challenge in electric watercraft; a wired connection eliminates this issue entirely.
  • **Screen can be locked - during usage in water & sleep-mode - during charging
What It Is
A complete touch-screen control system for electric watercraft. A single Teensy 4.0 drives a 480×480 full-color display, communicates with the motor controller and battery management system (BMS) over dual CAN buses, and handles GPS navigation, safety logic, and trip logging—all within a single, highly maintainable codebase.
By the Numbers
  • ~9,400 lines of C/C++ | 55 modules | 3 build configurations
  • 19 display pages | Tacho, GPS nav, BMS, motor data, settings, trip log
  • 100 Hz live tacho refresh | Ultra-smooth needles and real-time RPM via CAN
  • 6 needle styles | Selectable RPM & speed designs via the settings menu
Core Features
:gear: Motor Control & Safety
  • Dual Input: Motor control via CAN bus or PWM (configurable).
  • Direct RPM Command: 0–6,000 RPM with an expo curve, live telemetry, and configurable output limits (Rookie / Advanced / Pro).
  • Air-Catch: Automatically detects airborne states (jumps) and caps motor speed instantly.
  • Cruise Control: Hands-free riding with multiple automatic unlock conditions.
  • Touch Lock: Screen lock feature to prevent accidental inputs from water spray.
  • CAN Heartbeat Gate: Safety cutoff that blocks motor commands if the bus connection is lost.
:world_map: Navigation & Battery
  • GPS Navigation: Tracks speed, heading, target navigation, return-to-base routing, and distance logging.
  • Full BMS Monitoring: Pack state of charge (SoC), cell data, and critical events—mirrored across all display pages.
:bar_chart: System Architecture
  • Trip Recorder: Stores up to 5 logged sessions in EEPROM (distance, duration, max speed, max current, energy used).
  • Advanced UI: Animated tacho startup sweep, auto-dim/sleep modes, and dual-state toggles with visual feedback.
  • Modular Feature Flags: Safety features can be compiled in or out depending on the build environment.
  • Non-Blocking Design: CAN, display UART, and GPS communication run asynchronously without blocking the main loop.
  • Watchdog + Crash Recovery: Automatic reset and diagnostic reporting on failure.
will keep you updated.
Wish you all a nice weekend,
BR from Switzerland
Fabian
Looks very nice!
What’s the current status of the jetboard itself?
Hi Ludwig,
the jetboard is stable since 2023. My daughter is driving the DIY one and I ride a Jetsurf (petrol version). I use the electric one with an MGM HBCi, an EMUS BMS and a 14S14P Molicell P42a battery.
I think I have seen that in the past. So I assume the remote is for the electric one? Will the design be available to others interested?
yes, this one is at the moment for the electric one. But I am also thinking about to use it for a petrol one. Just changing the CAN or PWM signal to a servo with a 0-120 rotational angle - should not be a big deal. Only concern, a wireless petrol one…is more dangerous.
In the last year my daughter and I have used the previous version, which was the basis for this.
Some pictures here:
Here’s a little tip that will help you finally understand how good your ergonomics are for DIY remote control designers. Hold the remote in your hand and imagine the trigger on the back is a blade. Now pull the trigger and answer the question: will it cut off your finger?
Looks freakin amazing :star_struck:
Nice job :+1:
@rttn fair point a good catch. The picture shows just the CFK rib of the lever. Finally there is a small 3D printed plastic part which will go Inside. This has to be adapted to the little fingers of my daugther. I have just used the CFK for pure testing.
Very nice. Oh boy, need to add characters to post
Me podria serbir para un takuma v2
Hi, everyone
A quick update on testing in Corsica.
I’ve been using the remote for 1.5 weeks now. No malfunctions or anything like that. The only weak point is a screw that holds the spring for the trigger. Unfortunately, it’s not A4 stainless steel, so it’s rusting. The remote now also has an “autocruise” mode. Basically, if you maintain a roughly constant speed, it stays locked in until you press the trigger. This helps my daughter immensely. After the vacation, I’ll check in again with a final update. My conclusion: wired has nothing but advantages. That’s my honest opinion. Best regards from Corse
Fabian
