The agony of choice πŸ˜†
My Favorite for next fly is a 70120 480kv with PLE gear 3:1 or 9:1
Best regards Frank
That will be a beast setup! Should go really well!!!
Run it on 14s with a 110mm cleaver prop!
You mean 70120 ?
I have the same motor Running a PLE 60 1:8.
Not on a efoil but boat. Did not run it so far.
You have right… 70120.
With Prop you used?
By gear 3:1used 140er, by gear 9:1 I need 210er Prop.
Greeting Frank
