The best board for all diy e-foilers
What I like so much on Waydoo boards, and I still not understand, is how they can unmount the master.
I mean, every board that I see until now on DIY boards, have all cables directly connected.
But they can unconnect the master and after transport you can reconnect it.
I wonder how this can be make in a DIY efoil board.
I need it cause I have not so much space in my car.
Someone have an idea ? or someone know a link of someone that make this possible ?
Thanks all
Denis
I think this is common solution for eFoil DIYers. I transport my mast disconnected. Board bottom is flat with 4 threaded mast mounting inserts and slot for motor wires. And one hole for cooling water supply.
Silicon gasket mold is 3d printed.
I think I understand… but I’m not sure :slight_smile:
Can you upload a pic of de board please ? the point where the master will be connect.
Thanks a lot
Denis
Ok thanks a lot… now I understand.
But… how the water it’s go trough that hole without leaking please ?
Thanks again
Denis
Silicon gasket is thicker then black rubber gasket and has a bump around the hole (hard to see on pic)
It is possible to do in different ways.
I usually do a small hole in The board just below my mast there my cables and connectors goes out so i can connect/disconnect them before i mount The mast on ny box. In this board i have The vesc installed in a box on The mast so it is The power cables going out. In my previous board i had The vesc inside The board with a small heatzink and fan for cooling, then i had The three motor cables instead.
Then i have a sealings behind The mast so it is usually not comning in any water to the connectors. The cables are sealed with sixaflex 291i so i do not get any water into The batteries in The box.
I haven’t fixed The finishing yet on The box :grimacing: but it is working without any problems.
Ok… now I’m convinced :slight_smile:
I must still study a lot in order make my own board… but I have a lot of time until next spring :slight_smile:
Thanks a lot all !!!
Please disclose what you mean, cant figure out the 2 flaws. Perhaps abit to little bottom surface?
Hi, just wanted to know how to solder this kind of connectors? What temp to prevent them from melting the casing?
Here’s what I bought.
Just buy this tool:
https://www.amazon.de/dp/B013B90GK0/ref=cm_sw_r_cp_apa_glt_i_TF5405YZJWWB9QX2D6P6?_encoding=UTF8&psc=1
Then you don’t need to solder…
Hello,
tosh.jah is right. These connectors are not intended for soldering. Good luck with your project.
Would you have a link to these connectors ?
Check the supplier’s product list or contact their agent. I can’t find the exact link but it’s there.
Most of us buy them here:
https://eu.mouser.com/ProductDetail/Amphenol-Industrial/SLPPA25BSB1?qs=qSfuJ%252Bfl%2Fd47LHg%252Bm%252BuNYw%3D%3D
where can i get these connectors the link you gave is closed please help me
They are called ā€œsurlokā€
If you search on the Mouser site you will find many
thank you for helping
Here you have the exact article number to find them on mouser:
Cheers :call_me_hand:
I couldn’t find the same, can you give me the link?
