I borrowed a friend’s FD max setup with my midlength 60l and 1250 front wing, was able to get up very easy. My weight is 80kg. Do you guys think it would work to build a tow boogie using the FD or takeoff components? I would cut down an old alu mast and insert thru the board and then bolt the battery assembly to the deck of the boogie. Question is, would the FD or Manta systems have enough thrust to get me up on a midlength? My intuition is yes it should work if starting from prone or knee position. Would be interested to hear if anyone has done it.
