Tow boogie general design
I run mine on 40AH LFP 40V, never managed to actually get this emptied.
100min watertime (on and off) leaves me with about 30% capacity.
So yes, I would expect more.
Please tell me more… Are you running LFP specific ESC and BMS? I’d like to use LFP but here isn’t a lot of components made for them. Also are you using small cylidicral cells or the bigger square block cells?
EVE C40 40135 cells 12s2p, RC charger.
There is no reason to use different electronics.
You just need the space to fit the cells in.
Just don’t straighten your arm completely; keep it bent at the elbow. If you’re using a VESC controller, adjust the throttle curve for a smooth launch.
Great session on Bruce DaBoogie hour and a half full battery.
Nice! What software are you using there to record the session? Looks good.
Looks like the app called Foil Sessions. It has many different foiling categories to choose from as well.
Thanks Tim. I’ll check it out.
