I tried to run my OutRunner Motor for the first time and the result can be viewed in the following video: (https://youtu.be/-anLKynMQao). Basically the motor is bipping and twitching a little bit what gives me the indication that the motor is receiving electrical power ( also measured it with a multimeter. Does anyone now what is happening? What is the reason for the bipping? I think that is related to the receiver beacuse i cannot make the Motor to rotate with the remote.
Once again, Thanks for replying to my messages/posts.
Yes that was also my guess. I thought it was something related to the receiver also i just wanted to hear the feedback from someone with more experience than me.
I just have a question regarding the power supply of the receiver. Here’s a picture of the receiver:
As you can see it was multiple channels (normal for a receiver). Do you have any idea if i can provide power supply through the channel 2 and then connect the receiver to the ESC through Channel 1? Or do you know if i can use the Bind Channel? The throttle of the remote is communicated to the receiver in Channel 1 that’s why i want to connect the ESC to the receiver through Channel 1
