Hi, I have an Electric Skateboard I would like to try to turn into a Efoil. I want to get some thoughts and opinions. Below are the specs of the E-Skateboard. Could I use all the guts and get a new motor that would work better? I think the motor needs a higher wat output.
Any help on determining what would be a good motor for this setup?!
https://usa.rideunlimited.co/shop/cruiser-kit
22 MPH / 13 Mile Distance / 6.6 lbs
General Specs
Power (SOLO & Cruiser): 840 W Max.
Rider Weight Limit: Tested to 110 kg / 240 lbs (riders on heavier end should opt for R drivetrain)
Drive System: FOC with Regenerative Braking
Throttle: Remote Control with user-tunable parameters
Battery Specs
Type: Lithium-ion
Voltage: 36 V nominal | 42 V max.
Capacity: 2.5 Ah
Charging Time: 80 minutes (each / using 2 A charger)
Connectivity: CAN bus to other Batteries and Cores
Enclosure material: Fiber-reinforced nylon (tough as nails!)
USB Type-C port for charging accessories
Sealed to IP65 spec
Charger Specs
Input: 100 V – 240 V | 50 Hz / 60 Hz
Working Temperature: -10 °C to 40 °C
Charging Temperature: 0 °C to 40 °C
C Charge Time (2 A): 2 Hours and 30 minutes
Charge Time (3 A): 1 Hour and 50 minutes
