I have a damaged motor wire from my 65161 that needs to be extended
I bought some cables but I am unable to tin the motor wire (no problem with the AWG 8 silicone cable I got)
so far I tried:
-acetone
-scraping with utility knive
-gas torch
In the worst case you can dip wires in a molten NaOH salt bath and get rid of both oxidation and whatever type of insulation but it’s a last resort, fumes are highly toxic and the NaOH will dissolve anything it gets on - including your flesh. Wear protection, do it outside etc.
I’ve had to do it on class H dual layer polyesterimide enamel wires that was impossible to clean otherwise. As said, it’s a last resort, i don’t think the common motor wires need it.
But did you melt it? Gas burner, a bunch of NaOH granulate, heat in a disposable tin can and add a teaspoon of table salt, heat ’til salt melts. Dip wires until clean.
