The Trampa VESC 75300 has a port for a power switch. The Raiden 7 also has a power switch port. I have used both these VESC’s.
When the switch is off the VESC draws almost no current so batteries can be left connected for very long time without discharging. I am looking at the FS75200 VESC. How can I tell if it has this feature?
This is what I believe to be the case. The only place you can purchase the VESC with the power switch, and hibernate function is from Trampa. It is was introduced on the VESC 6 MK 3, 4, and 5. It appears the Flipskys 75/200 is based on a older hardware revision. Does not have the feature.
NOTE: The Raiden 7 also has it. I’m thinking they must have built there product to the new hardware design. Unfortunately the Raiden 7 product is out of production. They say maybe by the end of the year or latter. I’m not holding my breath.
Confirmed, it does not have the feature. Best bet is an in-line fuse / switch on the power cable for the Flipsky 75200.
