So, I remember setting the current for both motor and battery to 50 amps while I was testing with the motor controller using the VESC tool. After successfully testing yesterday, I connected to the motor controllers with the VESC tool and read teh configuration. I found that battery current was set to 25 amps and motor current to 400 amps (not that they could pull that). So. here’s the question, do you think the motor controllers were limiting to 25 amps?
Did you remember to save the settings? Did you run any wizard?
Yeah. I remember the motors spinning up when I ran the wizard. But the question is; is the battery current currently limited to 25 amps?
The wizard tends to mess with the settings, so just go in and switch them to the right ones.
Yup, it totally is. In the settings.
Thanks! That’s good news. Means I have another 75% of power.
