What lake is that? Switzerland is beautiful. Maybe next year I’ll come and join the group! Be careful of that open prop too! That hangs way far back.
Today’s test. After few settings its so stable with a canard configuration from Crazyfoil…so cool. Speed 20kmh and 30A current
Hello Vincent, did you inverse the two foils?
30A ? That’s incredible !
@8S?
If so than you would earn the official EBEA (Efoil Builders Efficiency Award)
No. The 30amps are With 12S…
Combination of walking over the water and splitting the water. Biblical pic
My final build with new wings from crazyfoil. Win 30% of drag…can ride now 40min with 12s and 20 Ah only…
That looks super cool! How much are the wings?
GoPro Is so cool…with gps data from 10 seconds
video does not work Vincent
Sorry know it should work…
Cool Video! Can you tell us all how you did the video with the GPS/ GoPro stuff.
Is it a feature on the gopro?
Great video! Like the gps, speed, g force overlay
Thanks Vincent. Can you tell me exactly which model foil and which options you purchased from Crazy Foil? And did the mast have plenty of room for the wiring?
Hi Vincent !
I see that you started with a oil-cooled motor from Alien back in october but changed to Pacificmeister’s built with an Inrunner + Gearbox.
Can I ask you why you changed your initial plans ? The oil-cooled motor didn’t work after all ?
I’m asking because I’m going for a 4kW 100Kv motor watercooled too.
Have a good ride in switzerland ! Maybe You’ll see the SeaBubbles cruising around someday !
Hi
Yes at the bigining I start with cooling motor with oil. But I burn my motor. Still don’t no if it’s because the oil who conduct or for overheating.
And the pod was to big.
