So I have connected everything together for a bench test. Everything seems to work except the motor doesnt move till the remote is at 26%. Cannt seem to find how to sycn/modify it so it starts at 1%, any idea’s?
Have you run the VESC input wizard?
There you should see what is happening.
It could also just be deadband settings
You can set deadband both in remote and in VESC and I think both default to 15%, if they add up, that could also explain this.
Thks for your response. I did use the wizard to initially set it up. Will try what you suggested.
