Waterproof 80100 suggestions
Hi guys,
I’m looking to find a good quality waterproof outrunner 80100 (or similar) somewhere around the 130kv range.
I see a ton, but not sure which ones are truly waterproof, rust resistant, etc.
Thanks!
I have never seen one. I have made one by putting a 80100 in a 3 1/2" OD tube, and sealing around the wires and the prop (motor) shaft.
Interesting. What would be a good waterproof one to use? I need low 100-140kv for my build (its not a efoil).
I can’t put this in a tube easily. Possibly with a mechanical shaft seal, but hoping to avoid that method and keep my failure points limited
