What esc for Flipsky 75200
Hi guys new here.
I am looking for ideas fir esc cooling,with the mast i have theres barely enough room for the 8wg wiring ,i have no way of getting a tube up there unfortunately.
The esc that came with the board (alibaba special from Hisun) is actually fine its the motor that seized.
So i want to replace the Hisun motor with a flipsky 65161.
Is there a way to keep the flipsky 75200 cool without watercooling.
Or is there a chance that the exsisting esc will run the 65161 without issue…at the end of the day its just a bldc motor.
Any help would be greatfully received.
I dont think the original esc is a 75200. TO run a 65161 or 70165 you will probably have to replace this too.
You are correct is a generic chines no brand in a waterproof box.
So i have decided i am going armstrong aluminium mast and fuselage with the HS 1850 front wing,this serves many purposes,they are readily available here in NZ ,large choice of 2nd hand wings,hollow center to route wiring and liquid cooling for the esc and there is a thingverse 65161 motor mount for the armstrong mast.
So yes am going with the above and the 75200 with a vx3 remote…decided on the flipsky 65161 120kv with a modded flight prop.
Thanks for all your help.
