Which pipe for water cooling ESC
Hello, I’m planning to use a water-cooled ESC without a water pump.
I’m taking water from an inlet in the motor cowling. I’m using a PU tube with an 8 mm outer diameter and a 5 mm inner diameter.
However, I’m not sure whether this will provide enough water flow to cool the ESC properly.
Should I use a larger tube or make the water inlet bigger?
no works perfect like this
