Im planning a efoil build, I will use a gong foil- still deciding. But one thing Im having trouble figuring out is how to route wires from battery/ESC box to the mounting plate of the foil? How do yall do it? Just carve a channel or do you drill a hole down the middle?
Okay, so the board is strong enough to have the hatch box and the mast mounted on top of each other? How much foam/fiberglass is in that area? From what ive seen most people do the battery cutout further up? Have you found any benefit or negatives to having the battery just infront of the foil?
