Hi everyone after reading most of the topic on forum I choose to build my own tow boogie and I’ve everything clear but not for the battery…
I’ve bought a sequre 12200 esc and flipsky motor 6384 but all the battery that could find on line are 48v 20ah max 1800w…
If my motor it’s 140kv run at maximum power at 4400w the battery it’s too small?
could someone explain me the best choice for my configuration??
I also decided to make a tow booge with a single motor. I don’t have any experience, but I realised from the forum that the sequre 12200 esc and flipsky motor 6384 are a good choice. I’m still wondering which controller is more reliable: Flipsky VX3 or Maytech V3.0.? And same like @Casch83 thinking what battery is best for this kit and where to buy it without any hassle trying to assemble it myself. Let me know when you decide where to buy from;)
“OK, so it’s better to buy the motor on AliExpress. There’s already one with a folding propeller and ceramic bearings. Do you 3D print propeller or buy it? Are you planning to do something extra for your motor? I saw on the forum that others additionally manage the motor for water protection.
I saw that you had some problems with the SEQURE 12200 settings because there’s no USB.
Is there anything I should know before buying it?” How its going with your project?
For the esc you must be need a usb programmer, you could find it on ali…
Motor in the picture it’s fine, in the forum you can reach a lot of 3d file shared for propellers and mast adapters…
