HI200
Voltage: 75V maximum (recommended within 16S)
Current: 200A continuous, maximum 300A
Features:
1, Based on the design of vesc75300 hardware principle
2, Using 18 mosfet IRF7759L
3, Independent gate drive
4, Independent power supply
5, Independent current sampling
6, Active filter circuit makes current sampling more accurate
7, rich onboard interface
8,independent two-way adc
9,support VESC TOOL official 75300 firmware
10,Four-layer board design of size 100x61mm, the circuit is reasonable and stable
Size: 122 x 73 x 30mm (Including heat sink)
https://yongitech.com/products/hi200-75v-200a-esc-based-on-vesc-for-e-foil-surfboard-hydrofoil
