Can anyone help me get a 3d file for it? Need it for a 3d scale model, would save me lots of work at my skill level;)
There is a 3 blade prop on thingiverse designed for the flipsky 65121. Otherwise, many of the other threads have got long discussions on this topic
Here is one of the two best efoil 3 blade prop stl: Flite prop clone:
Dimensions: Fliteboard prop alternative to FR? - #13 by superlefax
by @superlefax
Thanks, very useful!
Have you reached a conclusion about a good blade for 3 blades prop for 6374/6384? If so, can you provide a model?
Did you try the common blade which is used for 2 blades prop?
The model on my grabcad works well, I am not the original maker of the file.
I ordered those blades in alu printed.
My custom blades by forging had issues on unfold, tolerances or shape, unusre.
Ye, I saw that you ordered alum and tried the forged.
On your grabcad there are have blades, but they seem big.
I thought you also tried the regular small blades…
FD uses same blades for 2 and 3
They are not big blades, 165mm DIA
I think @rttn sent me the blade file. So far I have not recreated a better blade model.
The alu blades have been shipped by pcbway
is it the one that you sent to PCBway fort printing en aluminium
yes, only one ride so far but worked well with PA12 hub.
j’ai voulu chez PCBway le faire usiner en CNC mais ils n’ont pas voulu du fichier. je leur ai demandé de l’imprimer en Alu alors. On verra bien.
I wanted to have it machined in CNC at PCBway but they didn’t want the file. I asked them to print it in Alu then. We’ll see.
I also uploaded files to pcbway directly, with some details about prints/materials, here is the link :
Thats a beautifull thing! Whats the pitch?
Thanks for sharing.
Can you share the step file for the blade as well?
I have a “similar” file in step, the one I made my forged blades out of, thinner profile, but unfolding was not as good for some reason (blade area, pitch, backsweep… whatever)
So I reverted to the previous file in stl and custom hub, I think the blade is from @V_S
This is not a file but a link to some options for 3 blade props at various price points:
