I’ve ordered two 6384 motors from different suppliers and both are actually only 6374! Hasn’t been much of an issue as I can efoil at 28kmph at 12s and pump up and efoil at 6s.
Where is everyone getting their motors from? Is it really worth paying 3x the price to get one from APS?
These are the two I’ve bought in the past.
https://a.aliexpress.com/_mMLQ2Ri
Maybe it’s time to measure your motors?
Jezza
April 8, 2023, 8:40am
2
I think it’s definitely worth measuring the stator. I know my 6384 from APS measures the same as the larger stators from the top 6374 manufacturers…
Yes the stator is quite big. APS advertise the 6384 as 4000W. Do you think that’s true?
I’m unsure if it’s worth replacing with a true 6384 or 63100 to get more power. My setup works very well as it is with only a 100a vesc
sat_be
April 8, 2023, 9:58am
4
I use a 63100 from APS bought in 21. It is quite powerful, I get close to 40km/h with 12S on an efoil. Phase current 158A, battery current 110A.
Jezza
April 8, 2023, 11:17am
5
That’s really decent! What wing are you using on the foil?
Jezza
April 8, 2023, 11:19am
6
Depends on what you want to achieve. I’m going to use my 6384 for a chilled foil assist.
sat_be
April 8, 2023, 11:20am
7
RL 1150 with old fuselage and old rear wing (mounted below fuselage), shimmed 1.5 degrees. Flite prop.
Larsb
April 8, 2023, 11:47am
9
There are measurements in this thread:
There are differences in what is called 6384 motor, the cheapest ones have 10-15mm shorter stator and can therefore not produce the same power or torque.
I don’t think 2/3 of a 6384 is enough to get up so that really matters.
My advice to anyone buying a 6384 motor is to ask for the stator width, if seller doesn’t know or won’t give you an answer then think twice about buying if that exact motor isn’t already verified to work in efoil/foil drive application.
I’ll see if i still have a fake ”6…
Slightly annoying that the links don’t work anymore, can’t that be fixed @pacificmeister ?
Anyway there are measurements and discussions starting from about post 560 in that thread.
