So, while my friend is modifying the board to accept the mast mount (more about that later), the work on the ESC is proceeding. After blowing many many parts, and finding out that 20A will cause the PC board traces to blow up also, my husband Charlie is building the real thing. Finally… As Rick says, if I wanted it next week, I would have ordered it next week!
The ESC is built inside a small AN-04F aluminum box (https://www.polycase.com/an-04f). Since the box is small, and Charlie required that all the wires exit from the narrow side, and also that we can disassemble the whole thing, and that the wires enter the box with a very specific placement… that ruled out a lot of neat solutions that I saw on this forum.
I built an extension box to accommodate 5 IP68 glands. The extension box will be glued onto the aluminum box.
WATERPROOF BULLET JUNCTION
While I am waiting for the ESC, I am building various bits and pieces.
Here is a waterproof junction to connect the motor and battery wires to the ESC. It is inspired from to many designs found on this forum. I wanted to make something that is easy to disconnect.
Wow looks super sleek.
And you were even able to reuse the original gasket.
Sorry to bother in your thread but since we are speaking about connectors…
Are there beefy AntiSpark Connectors without a housing, I’m speaking 8mm or higher. All I found so far are the AS150. But I’d like to go bigger.
I’m back! The project was considerably slowed down by the early start of the wind season, here in California.
Here is what we are doing for the battery (the ESC is in a different box, don’t look for it here…):
Initially, the battery will be housed in a waterproof “Nanuk-made-in-Canada” 915 suitcase, with an polycarbonate panel for added waterproofing.
The suitcase will be tied to the top surface of the surfboard, for now.
Circuit breaker: 50A (we are still under the delusion that it will be enough)
Car relay: was cheap, that’s all I know. Activated by the house alarm switch to provide a “dead woman” off safety.
House alarm switch: a magnetic switch that is opened/closed by another (external to the suitcase) magnet. This magnet is attached to a leash and opens the house alarm switch when the rider falls off. This, in turn, triggers the car relay to open.
Et voilà… We’re using 6 AWG wire… The (redundant) polycarbonate panel still needs to be installed, and the 2 holes for the waterproof glands are not there yet, but I’m scared to drill my beautiful suitcase!
Anyway, this leaves the top half of the suitcase free to carry a beer, a sandwich and a change of clothes.
We found some central office power supplies on eBay for cheap. You can program the voltage (max 57V) and limit the current (max 20A). Was something like $30.
Testing the battery
Battery -> ESC -> Motor (MTI65162) -> propeller in garbage can full of water.
Ran at about 750 to 1000 W, steadily to check the discharge of the battery. Seems OK, for what we know…
I’m back after a loooong break. We are testing by placing the motor and propeller vertically in a garbage can filled with water. The load is provided by a variable weight placed on the lid. It’s not ideal, but we get a vague idea of the relative efficiency of the propellers, by looking at what rpm and current is required to lift a given weight…
