Most of the major bits have been collected so I thought I’d start to keep track of the build.
I started building a rifle case foil build last year but that got side tracked and after getting to ride a Lift I figured that it would be a better time learning to foil on a shaped board and then switch to the rifle case once I want something smaller.
Appletree carbon wing foil board 5’7" or 170cm for my donor board.
14S10P 21700 P42A individual fuse battery pack in a split staggered design so 2 14S5P packs with no BMS so I can balance charge with my hobby charger.
Battery box is from amazon and will just fit my pack I hope, it does in the CAD, I’ll find out soon
MakerX G300 controller
Flipsky VX3 remote
65161 120kv flipsky motor
qs8 antispark connectors
Cedrus mast and Armstrong fuse coming soon
Next step is to print the battery holder plates this weekend hopefully and weld the pack together before I finalize the compartment size for the donor surgery.
