※※※Applications※※※
- Hydrofoil
- Electric Surfboard
- Electric Paddle Board
- Kayak
- Electric Skateboard
- Electric Longboard
※※※Features※※※
- Excellent waterproof performance: By using magnetic encoder, waterproof screen and wireless charging, the protection level of remote controller IP68 is realized
- Multi-parameter display: Speed, Direction, Battery status, Bluetooth and GPS signal status, ESC temperature, motor rpm, Cruise status, and Throttle
- Multi-protocol support: VESC Communication Protocol, PWM, Dshot300
- Integrated housing: The shell is glued using ultrasonic technology to improve the operation comfort and appearance
- Multi-operation mode: Throttle, Cruise (10% step length increase or decrease)
- Convenient charging: Wireless charging technology is adopted to realize remote charging and use
※※※ Rating※※※
Handle (Transmitter):
Waterproof: IP68
Sensor Type: Non-contact Hall sensor
CPU: NRF52840
Battery: 3.7V/1450mAh
Endurance Time: >10 hours
Display: 128x128 1.5” OLED, Yellow screen
Receiver:
Power Supply: 3.3V
Throttle signal output: 1-2ms 50Hz PWM 5V Max/VESC TTL
Voltage detection range: 5-60V
Wireless charger:
Wireless charging standard: QI
Input interface: Micro USB
Input: 5V/2A
Output: 5V/1A
Charging power: 10W
