Bremote connection for dual steering ESC + BEC
Hello, i’ve seen some similar posts but not with a diagram, i think this might be a common question since there are quite a few connections to be done - so it would be nice to be able to have it as a searchable post.
I’m connecting two ESC:s and dual BECs to the Bremote receiver for a dual motor steering tow boogie.
EDIT: Removed pic. See later post
@ludwig_bre: Is this connection diagram correct? Pink and grey lines are BEC low voltage connection, black and red full battery voltage as usual (i know the original diagram doesn’t separate low and high voltage connections)
Looks good, the BEC2 may also connect directly to the red and black going towards the 2nd output, right now they are just connected to the top of ESC2
Ah, i see, you mean to connect the lines where the 10k resistor is connected, since this is the actual routing. I tried to graphically match how the esc has it’s connections. I’ll update.
This one is probably more clear.
OK @ludwig_bre ?
Yes, perfect
20char…
If I don’t need a BEC, do I just connect pink to red and grey to black - same wires just by-passing the BEC? Thanks!
