Inspired by this thread (Light assist Season 3) and the safety discussion, I wondered how hard it would be to connect a gyro to the Rx?
At least in a foil assist situation, it seems pretty easy to eliminate most situations where you could get near the prop.
Under load the board should have only minimal roll and very limited yaw over time. If you combine it with GPS speed, you could also improve it a lot.
