@baein …That dude is a bit of a troll…ignore him. I blocked him in the end due to his never ending “views”…
K
@rttn you come across to more western cultures as a bit aggressive when you loose your temper. In my experience using russian argumentstion style does not translate well to english. But I disagree @rttn is a troll. He is very active with strong opinions, and willing to share his work. Beeing culturally different in communication style and arguments is not the same as trolling. No one will win this, everybody stop now, and chill a bit. You have work and wives for endless arguments, not this forum :laughing:
I think you’ve misunderstood a few things here…
When @baein referenced the Magpul, he was talking purely about the grip, it had nothing to do with the trigger or trigger design. There was no need to jump down his throat about the trigger.
You are forgetting everybody’s hands are different sizes. This trigger design may suit @baein perfectly and add safety to his setup. He’s in no way required to add safety to your setup though. DIY is about doing what suits each individual…
Let me try to explain it again. There is no free space in the trigger guard. Let’s say you put your finger on the trigger guard and you don’t intend to start the movement. But as soon as I clap my hands above your ear, if you don’t expect it, your hand will reflexively clench and you will start the motors. I can admit my own wrongness at any moment if I hear arguments. Can you reasonably object to the example above?
Temporarily unbanned Konutz.
Here’s a memory pill for you. Once upon a time, a troll asked a very important KONUTZ to make a video of himself riding a tow boogie. Very important KONUTZ promised, but of course he didn’t. And then something terrible happened. The troll had the nerve to write the following: “Allow me to remind you of my request.” Unheard of nerve, no wonder very important Konuts went into hysterics and started screaming that he was being forced to make a video. I have a question: if you manipulate, change names and publicly complain that something is being demanded of you, when in fact you are being asked, then who among us is a troll?
@ludwig_bre I found some videos about a v2 nano on your channel!
Though I’m missing a display, it looks fantastic!
It indeed looks so good, that i would like to adopt it for my new build :smiley:
Can you already tell us, when the the nano will be released?
thanks, Fabian
Hey Fabian,
I am still in beta testing, but it’s looking good. I think I can release the files in a few weeks.
It is probably too late in the development and I guess buttons are not really easy to waterproof.
But for starting as foil assist on a small board, I would lave to have a button you have to hold to lock the current throttle value.
That way you could accelerate with the normal throttle and once you are up to speed you just hold the extra button, i.e. in the palm of your hand, while getting up on the board.
And once up you use the regular throttle again.
The nano has the small toggle button on the bottom, you can reach with your index finger
I cann add a mode like you described
Yes, you are right, that should work.
Great!
Hey, some “Simple” ideas to improve V2 display ergonomics, probably already thought about?
In main “active” display, use the available vertical bar besides vesc temp and battery to display throttle 0-100%
Use the middle horizontal bar to display the steering input, flash the central light when in neutral steering, then use the 3 dots each way to display the steering effect from -100 - 100%
Use the second lowest horizontal bar (above the RRSI bar) to display battery %
Adam
Thanks for the ideas
Out of curiosity, why would you like to see throttle and toggle/steering information?
Battery is already displayed right, why also display in the bottom?
Sorry if not clear, I mean the remote battery.
I use the remote on the tow boat that I also ride as a boat with family, with rides at trolling speeds that can last 3-4h. Just a way to have the info without restarting the remote. Also cruise control would be nice for this use.
I had a servo failure on the tow, and having a feedback on the remote could help diagnose immediately what could be wrong with the boat and react quick. If you have signal, and the remote feedbacks throttle/steering signal being transmitted, you can rule out remote inputs failure. Same idea for throttle.
The boat was far and into a channel with other boats, I could not see if the steering had any effect.
Understood
I think adding all this will make the display too cluttered but I will try
Anyways maybe some information/tips that also help:
  • Internal battery lasts 40-60h on one charge. So as long as you start with more than 3.7V you should be good even for 4-5h rides
  • To debug inputs, if you have locking or gears enabled: If you apply throttle you should not be able to switch gears. If you can’t, throttle is read correctly. If you don’t apply throttle and can switch gears the steering still works correctly.
Small teaser, more information coming soon
2025-08-30_19h31_07
Let’s go! Will this be the follow-me breakthrough?
Will it be backwards compatible with the existing V2?
Love your work Ludwig, thank you!
Another thing I might share at this point :smiley:
Backwards compatibility if you did not fill the remote with potting material or keen enough to Dremel and pick out parts of it again… otherwise new TX with the GPS included is needed. Rx is fully compatible
Inspired by this thread (Light assist Season 3) and the safety discussion, I wondered how hard it would be to connect a gyro to the Rx?
At least in a foil assist situation, it seems pretty easy to eliminate most situations where you could get near the prop.
Under load the board should have only minimal roll and very limited yaw over time. If you combine it with GPS speed, you could also improve it a lot.
I2C gyro can be connected to the bus thats already there
In fact V1 remote had acc/gyro onboard. Was never used so I removed it on V2
According to a friend working for a big efoil company most prop injuries come from feet below board and throttle engaged btw, not falling and getting close to prop.
I can see that for EFoil.
In a foil assist situation, with the motor close to the board, it seems possible, but pretty hard to do.
The few problematic situations I had, were when I was falling and still holding the trigger or more frequently, when I was falling and the trigger was activated by water pressure.
I will see if I can figure out something this winter.
