The housing is made of aluminum.
ESC cooling as last time, with water without a pump. We do not use hoses and native fittings.Remove the back cover, and place the camera over the water inlet opening from the mast. It works well!
Thanks to Thrustfoil and his magic machine! The board from the 3-d model has turned into something that you can touch with your hands! I didn’t seem to make a mistake with the size! It will be like this! It remains to be pasted with fiberglass!
The new engine and BMS have finally arrived.
The hole on the shaft is drilled very close to the engine housing. To tighten the Flite screw, you need to put a bushing. The thread does not reach the edge of the screw.
Finally, the new board is ready for lamination.how do you like the size? Will I be able to stand on it?
What’s the board volume and you weight ?
I think you can enter the smallest board challenge… ![]()
The volume of the board is 88 liters, my weight is 93 kg. When I weighed 85 kg. I was windsurfing with a volume of 70 liters!
I’ll join you with the same size. Just a little different hatch system.
Also around 93kg myself.
Hi, Anatoly! Could you please describe which specific components you used in this battery pack? This is the first time I will build a battery myself and I want to assemble something that will definitely work. Thank you!
Hi! This battery uses Tesla 21700 elements, and BMS with power keys. I’ll reset the link. And nothing else. The BMS was with a screen. And I had to solder the button to the standard button that stands on the side of the bms. And the connectors themselves decide which ones you like.
655,68 руб. 22%OFF | Плата для защиты литиевой батареи Smart Ant BMS 450A 300A 200A 100A 70A, Bluetooth, li-ion, Lipo, lifepo4 LTO 10S до 24S 60 в 72 в 20S
Hello everyone Yesterday I was able to test and compare the Chinese waydoo product with my board! To be honest, I’m not thrilled with waydoo! I expected more for such money! It comes off the water easily, and goes out on the wing too. It is not necessary to crush the nose as much as on mine during acceleration. But in displacement mode and on the wing, my board is more stable.
And it buzzes very loudly!I don’t know why. There’s no gearbox there, is there?
