This size turned out to be very important. If it is less than 300 mm, the board tries to stand with its nose to the top, we crawl in front. When I tried to stand on it, in short, like a chicken on a pole!
We are learning new poses.
Hello.
Did you menaged to repair 70141 motor?
Its strange that is burned.
Thare is no black burning marks, did you check soldering joint whare phase wires connect to coils?
Maby cold joint or desoldered from heat.
No, we haven’t done it yet. We replaced the motor with a flipsky 65161. Maybe it didn’t burn, but there is a smell of burnt wires. And there is a problem with the rotor, the film on the rotor is damaged, the magnets are scattered.
I use a similar hatch and managed to get it waterproof by adding a second seal next to the original one.
Mine is recessed in the boards with drains on both sides to avoid water on the board after takeoff.
Satisfied with the solution now.
We also glued an additional sealer, but it didn’t help. You can post a photo as you did. What kind of seal did you add?
I used Qishare from Amazon;
Qishare Silikonkautschuk-Dichtungsstreifen, mehrlochiger Dichtungsstreifen für Türen und Fenster, professioneller selbstklebender, kollisionssicherer Schallschutz, 6M (E9 * 4mm * 6Mx1, Weiß) https://amzn.eu/d/bXW6kM9
It looks like we have different hatches. You have two black seals, and I have one.
We disassembled the flipsky remote control after two seasons of work in fresh water. The mode switch button does not work. Now it’s clear why.
We have one remote left! Of the three, two don’t work after two seasons. And in the third there was a spot of moisture on the screen. Flipsky needs to be improved! But how?
the second black seal I glued on; not part of the original hatch.
Its this one:
" SCHWARZBERG Self-adhesive sealing tape, universal, 6 mm x 3 mm x 5 m, thermal tape insulating for windows and doors, foam made of cell rubber"
Hello everyone I want to express my gratitude to the FLPSKY Official store.In place of my damaged remote control with sea water, I was sent a new one!
FLPSKY Official Store
Remember this photo. My friend made me present! In the image and likeness! These are such cool T-shirts turned out!Thanks to him!
