The season is open! A week earlier than last year!
My 75200 is filled with compound and placed on copper tires without water cooling works well! A month has already rolled back! With very aggressive skating, it does not heat up more than 48 degrees! I’ve never blacked out! I’m happy so far!
And on a small board, the deck hatch had to be replaced. They made a hatch made of sheet plastic and a silicone gasket for food molds based on platinum. The locks were also abandoned. Put 12 bolts around the perimeter! Now holds the water!
We had a good ride yesterday!
We catch up with the boats and ride their wave!
That’s why we ride in helmets! Today I gave a ride on my board to a friend. He unsuccessfully fell forward with his feet and hit his head on the screw while surfacing! It’s good that he was wearing a helmet, but the screw could not withstand the impact! My favorite screw!
It’s a pleasure to lay turns on a short board!
And in this photo you can clearly see how the passive cooling system works from the incoming flow. Without a pump. Two fat jets coming out of the esc!
Do you have the ESC above the mast or inside the electric box ?
In this esc 75200 board with a water body in a box, the bottom cover is removed, water flows through the mast under the cover and exits through two holes, no tubes. But in other boards, I refused this as well. The 75200 without housing is mounted on a copper plate, and the plate is in a sealed aluminum box. And everything is flooded with compound
