I used the Permatex sealant I referenced above. Messy but seems to work well.
I sealed the hole in the side of mast where the motor wires enter and then sealed the top of the mast where the wires exited. The bottom of the Gong V2 mast has rubber seals between the wire hole and fuselage connection already so I’m quite confident the inside of the mast remains dry.
Let that set up as its messy and I didn’t want to wiggle the wires around much to keep the seal. I think this point is very important to allow the sealant to “fix” itself to the motor wires.
Installed mastbase and sealed that hole and let it set again.
My adapter plate is a bit different, thicker and different hole placement. See photo before I through drilled and tapped for the connector bolts, so my wire hole is directly above the hole in the mast forming a deep chimney for sealant.
Things got really messy from here on as I had to put the thermal paste on and not get it where more sealant was needed. Lots of paper towels, qtips etc but managed to get more sealant in the wire hole and on the threads of the holes and bolts. Get it all together then let it set for at least a day. The sealant is designed for high temp motor gaskets so thicker layers take a lot longer than it’s design spec.
The bolts were short enough that I could put more sealant in the holes from the top side of the plate.
Clean the plate and the bottom of vesc and apply thermal paste and bolt the vesc to the plate.
I have not made a cover to go over the 75200 vesc. I managed to get the whole thing inside the board and secure it with the 4 Flite bolts through the ears of the adapter plate - of course with the orange Flite seal in place. I will figure out a 3D cover for the wire “glob” on the vesc this winter when I can’t foil!
I do not need to remove the adapter plate from the board to transport, just take fuselage off and it fits in my van.
I have had multiple 1hr sessions and the vesc temp has not gone above 31C and not a hint of water inside.
I am so glad to be rid of water cooling through the vesc as it was always prone to a big leak and bad things happening!! NEVER AGAIN!
Lots of aluminum heat sink via vesc, plate, base and mast
Hope this helps!! Great rig once you get it sorted!!
