Building an 18650 battery with individual cell fuse wires
Hi.
Thank you. I’m glad my build has been of benefit.
There is an enormous amount of information on this forum. Under your profile you will see your summary of read time. There is no short cut to reading. :rofl::sob: Once you have several days of read time things will start to make sense.
There is no one way to build an e-foil. Everything is a compromise. Get about 5 days of reading and you’ll figure out what you want before you start buying stuff and building. This will save yourself from a lot of waisted time and money!
We’re all here to help. Good luck with your build.
:call_me_hand:
Hi guys.
I’ve had several questions about the acrylic battery box. Here is the dimensions and what to buy.
1/2" acrylic for sides
3" tall x 14" long
3" tall x 13" long
1/8" acrylic bottom
15" x 13"
.093in Lexan top (do not glue, attached with 1/2" 3M VHB tape)
15" x 13"
Glue
Weld on 4 thin chemical bond
Weld on 16 tube thick glue type secondary seal on inside of seams
Google how to make an Acrylic fish tank for glueing instructions.
:call_me_hand:
May i ask a stupid question.
Why do we not put cells in series first and then in parallell? Then we could have balance-monitoring/charging on each individual cell, but i guess there is no chargers with that many balance-leads
Like this:
= is one cell
“+ Plus ’ ’ ’ ’ minus -”
Hi.
For my 14s14p battery you would need 196 balance leads if you tried to do that.
You drew a 14s3p battery. That would need 42 balance leads. Most balance chargers do up to 8s. So, you would need to combine the 3 groups of parallel cells, and split the series cells into two packs and have two 7s3p batteries.
:call_me_hand:
yes i understand that would be a problem, but if we had a charger that could handle 196 balance leads, would it be worth the extra job of connecting them this way just to get the benefit of full controll over each cell? or is it not a benefit?
i’ll just go with a standard setup! :slight_smile:
you say you have 1,5 h ride-time, i think i need to compromise on ride time to keep down the cost but i still want to go with 3000mAh cells but then i might want highter discharge rate than 15C?
if i build a 12s10p = 120 cells with 20C/cell then i still have 200A total discharge but only 30 Ah opposed to your 42Ah. (30Ahx50,4V=1500Wh) opposed to yours (42Ahx58,8V=2470Wh)
that is 39% less capacity, am i right in this calculation?
Hi.
I am by no means an expert. But, my opinion.
Samsung 30Q cells are among the best you can buy. But, even these have their limits.
You can see my YouTube videos I did on testing these cells.
The cells do not get too hot at a continuous 10A discharge rate. They gets really hot at 15A. And they are so hot the will burn your hand, and start to “melt plastic” at a 20A discharge rate. They are not really a 20A cell. See manufacturer specifications.
They are still within the manufacturer max temperature limits at 15A discharge (75°C = 167°F) , but just so you understand that these cells get very very hot at that rate.
I would build your pack so with your conservative power consumption under continuous use results in no more the 10A per cell draw.
The heat can be a problem in a sealed batter box, and the cells won’t last as long.
It would be better to do 12s14p in my opinion. But, your use might differ from mine. I routinely ride long distances and I use my efoil board to tow other foilers into waves. So, I need the extra margins.
Hope this helps.
:call_me_hand:
Hi Flightjunkie, so I am building a battery pack based on a combination of inputs from this forum. I really like the idea of individual fused cells, for aditional safety. So I went ahead and also tried to burn through the 26AWG wire with a single cell (spare one). Although the current was much higher than the “recommended max 10A discharge”, the cell did not get warm and is still tested to be normal.
The fuse current of a 26AWG wire is roughly 20A according to this site, so seems fine to me:
Fusing Currents versus American Wire Gauge for copper, aluminum, iron, and tin (Cu, Al, Fe, Sn), wire melting currents (powerstream.com)
Now the idea is:
  • CASE004 IP67 case (thought that 14s14p would fit, but doesn’t due to angled sides of the box).
  • 3D printed battery holders, will now be for 14s12p.
  • I bought the Q8 charger which you have too, but…
  • I Would like to use one Li-ion charger and a seperate balancer board to keep the cells in sync.
  • Use refurbished LG cells MJ1 cells, all with >90% tested capacity.
Do you have any experience with such a balance board (its not a BMS indeed)?
Thanks!
Nice pics
I put a link for balancer board last year but I think no one has done it yet , and it will probably take forever to do the job
For the case 004 , yes you can fit the cells without full spacers just separating them in the row with 2mm , find this solution at the time but did not do it and you have some room in height to overcome the round bottom side ( rising the all set by 5mm)
Looking at your printed spacers are you sure you can fit 14s12p in that case ?
Hi.
The individual cell fusing works great. I have built 4 of these batteries and after a year they are all working well.
I think the balancer board is low risk, unlike the very dangerous BMSs. But, I also think it isn’t worth adding.
My understanding is balance boards work by discharging the cells with the highest voltage untill they all match the cell with the lowest voltage. And the max discharge current is usually around 100ma. If we’re talking about a 14s14p battery with 3.0ah cells, that’s means each cell is 42 amp hours. It would take 10 hours to discharge (balance) just one amp.
Not sure I understand what you want to use the balance board for? Keeping the cells balanced during use, or balancing the cells while charging? Would this balance board be directly hooked to the battery and left attached permanently?
If you use a balance charger during charging (like the iCharger X8) then the battery will be fully balanced by the charger and the balance board isn’t needed. During use the battery will not get out of balance enough to notice unless you have a bad cell, and then when you balance charge it during the next charge cycle you will see this because that group will need less amps to charge than the other groups. So again, balance board not needed. And if you leave the balance board connected all the time I would fear that it would slowly discharge the battery during storage?
Just sharing my thoughts on the subject. Lmk if I missed the point all together.
Have fun with the battery build. And be safe!
:call_me_hand:
Looks the same as the active balancer i have intended to use on my sup motor. Not tested yet. Will also not use a BMS due to safety, but my plan is to use the balancer at storage and while charging, but will remove it when using the sup(this also for safety). It can not do anything during the short time battery is discharged anyway. It is probably very slow, but when finally cells are in good balance, dont think it has to work that hard . Will use a simple automatic charger( auto cut off when voltage is reached) but that has no balance function.
@ Alexandre; well they should fit. Originally I designed with the 18mm of a "18"650 cell and the inside dimensions of the box (square). Should have fitted 196 cells. But…
  • The cells are in fact 18,3-18,4mm in diameter
  • There is a label placed on these used cells by the inspection company, which is almost impossible to remove. Thus randomly the cells are 18.5-18.6mm in diameter.
  • I like the idea of having a small gap between cells to make sure the outside (GND’s) are not touching.
  • Well I ended up making a spacer for 180 cells, of which I will used 14 * 12 = 168. (13*13 = 169 would also fit).
The remaining space will be used for the inside of grummets/connectors and an additional 200A fuse.
Due to the size of the printer bed, it is made out of two parts. Which should connect with mini dove tails. I tried different holder shapes, but pins with a small angle to them have a nice alligning function and are the strongest (3D printed).
@ Flightjunkie; good point you are making. So I had a look at the IDST Q8 manual, which states the max balance current is 1,5A/cell.
Manual balance voltage
The balance board has a max balance current of 1,2A/cell, which is relatively close to the charger. I see a couple of fat 1Ohm resistors on the board which I asume will indeed burn the difference to balance.
Now I have two options:
  1. Permanently attach the balance board (thus inside the enclosure). It is possible that it will not keep up during discharge, but it will do its job during charging.
  2. Make two “7s12p” batteries and use connectors like you did to balance them externally with the charger. (could also do this with the balance board).
I like option 1, thus only two wires going in and out of the battery box. But I need to test this under load to see how hot the balance board runs and how (un) even the cells turn out to behave.
The balance bord will discharge the highest row to the lowest … all the time , so not the best if something goes wrong …
The new icharger x12 is out : 12s , for 14s still need to split the pack into 2x 7s
But another idea , is to do a 14s pack but to add a charge plug in the middle , so you can charge one 7s side at the time ( even if the rest in weld together ) so only 2 bus bar , 3 charge leads , pack charged in two times
Thanks for the input! I really like all the feedback I receive. I will add the “fatter” charging lead between 7 and 8. So that ability remains.
Well for time that something goes wrong I have the individually fused cells. That should help if one cells quit doing its job. My idea is that the if 1 of the 12 parallel grouped cells goes bad, the balance board is still keeping up while charging the complete battery pack in series. Let me try to illustrate below.
Theoritaclly the resistance of this parallel group now deviates with 8,3% with the rest of the pack. If I charge it with 4A in series. The deviation of one “bad” cell, would result in 4A * 8,3% = 0.332A of balance current. With the ability of the balance board to balance 0,7 A under preferred conditions, gives a Margin of Safety of 2,1. (1,2A gives a MoS of 3.6). This leaves room for individually cell deviations, faster charging etc. But again I have to see if it will work.
Very interesting , never found out if one cell goes bad if it’s resistance would very high or to none …
I see 19 x 9 and 10 : waiting to see how you wire that evenly in a 14s pack
Li-ion batteries must be balance charged. Either with a smart charger that monitors each cell voltage, or with a BMS that monitors each cell voltage and can interrupt the charge current.
A balance board with a 2A discharge current is not enough to prevent damage to your battery, and or a dangerous thermal runaway.
There are a lot of reasons why the voltage can spike on any given cell group during charge. The charging system used must be able to stop the charge if a cell group exceeds 4.2 volts.
I have had many times when my charger stopped charging because it detected high voltage on a cell. Any Li-ion balance charger will do this.
Charging your battery the way you describe is extremely dangerous and sooner or later the battery is going to explode or catch fire. And if you haven’t seen what happens when a 2 Kwh battery goes it’s scary. It’ll burn your whole city block down and or destroy your car.
Once the battery has been damaged with cell voltage above 4.2 it’s a ticking time bomb. It might thermally runaway while on charge, or it might later while being stored or used.
Commercial built batteries that charge with a simple charger are protected by a BMS that monitors the individual cell voltage and can interrupt the charge current if a problem is detected. I don’t trust BMSs. So I balance charge.
These batteries demand respect. Please be careful.
:call_me_hand:
Watch this video to see what happens if your efoil battery catches fire.
Holy… that is some serious fireworks. Message is clear, don’t joke with overvoltage. I think I will solder three balance leads (2x7s to external and 1x14s internal) to the battery pack. Since I can always simply open the case. The external ones are for the undervoltage alarms during riding. But I hope the vesc/maytech remote gives a good enough estimate of battery status.
For charging:
  • Either split the pack in two with a RC charger.
  • Try the balance board (and set the upper cut of voltage on 93% if total voltage) Of course carefully watching the cells during the charging.
  • Just order a low current BMS for charging only.
Thanks for caring!:call_me_hand:
Whether you use a BMS or balance leads, the routing of balance wires is important - avoid crossing them, and don’t allow them to be rubbed/worn or crushed. Any shorting between balance leads, or to a battery casing, could cause disaster. A balance connector is another place where shorts could occur.
