Cable position - effect on ventilation
I want to share something that I figured out.
During my first rides with my foil assist I had problem with ventilation of the prop. The change in thrust was very heavy.
With a few iterations I camed to a setup where this is not a problem anymore.
What maked it working:
  1. the three blade prop from foil drive
  2. a cable guide that leaves a small gap between the mast and the cable.
    (Cable guide for DIY foil assist by StefanG - Thingiverse)
I think that the gap reduces the amount of air that comes down to the prop. (like the good old anti spin out fins for windsurfers - the old boardheads may remember theses things :wink:
