The mast only needs to be glued if it has play in the plate and is therefore not stable, or if it wobbles a little or needs to be tight.
In muy foil setup one of the holes to attach the mast to the base plate has become to big for the bolt so I will fix it with a modified washer and I think I’ve better if I permanent assemble the mast to the base as Fanatic does nowadays. Less risk of future play or woobles.
does anyone have a gong v2 top plate STEP or DXF ? @nice2cu
I’m looking to use the layout to make a angled riser for my TOW
Thanks!
How exact do you need it to be? I think i have a rough version somewhere
well, it’s just to make an angled riser so even if it’s not perfect that will work.
Sorry no.
I not need it.
I have just made the Gong V2 mastplate in CAD. Fits very nice, accurate in +/-0.2mm. Hole pattern tolerance +/-0.1mm.
Plate only + holes for mast
https://grabcad.com/library/gong-v2-mastplate-1
GONG FOIL ALLVATOR V2 TOP PLATE
thanks a lot ! if any of you have the UNIFOIL Katana mast I’m down for it !
I sketched an F1 mast and uploaded as STEP here:
I’ve tried a 3d printed section against the real mast and the accuracy is good enough for clamp design
I sketched an RL boards mast and uploaded as STEP here:
These two masts share the same profile (not the same hole pattern)
The RL mast is considerably beefier in thickness than the F1 mast.
Does anyone know the dimensions (width and thickness) of the neilpryde and cabrinha aluminum masts?
I sketched and uploaded the Crazyfoil mast here: https://grabcad.com/library/crazyfoil-hydrofoil-mast-1
It has a symmetric profile and thickness is low so i don’t expect this mast to be the best.
I got their kit when I started, their wings had quality issues and the customer support was horrible - but if you’re unlucky enough to get one then this could be a base for clamp design.
Hey everyone,
Does anyone know the spacing for mounting an Armstrong mast to a board?
anyone have the hole patter and shape of an Airush core foil 2019 mast?
Thank you. I believe that the step file for the 19mm Gong V3 mast was already shared some time ago.
Does it correspond with your mast data?
*Edit. found it: 19 mm Mast by Nabazul | Download free STL model | Printables.com
I just ordered this: 12in 3K Carbon Light Sleeves (sold by the running ft) - Soller Composites, LLC
Carbon fiber sleeve. Idea is to print segments of mast in PLA, glue together, significant infill with epoxy/filler, laminate with carbon fiber. Lets check it out. Maybe will work.
Idea here is to be able to place the motor in 2-3 different positions in one session with watertight electric connection. Commercial designs are pathetic - no imagination.
Have you had any experience producing functional items from PLA before?
Sorry for delay in responding. My screen name explains it all. I finished printing a motor adapter in PLA. I am going to add a layer of carbon fiber and test it. Is it a bad idea?
