Hi you have build a amazing Flyboard but which Motor have you used?
As mentioned the one from Flying Rodeo
WOW ! great !
what ist the electric setup?
Ducted Propeller , Gear , Motor , ESC ,Battery … ?
Very nice build. You are inspiring me to start my 3rd build.
Please read my profile and my topic carefully.
Thank you
Awesome looking build, what is final thickness of the board, 30cm?
30cm seems really thick. I’m 127kg and was thinking of making mine 15cm thick.
Thanks, the thickness is 14 cm.
Ok, for a moment I thought i was going to waste time to make a board that was going to be small on volume.
Hi. Can you give the link to get the mast? Seems like the supplier only sells the wings and the fuselage.
Thanks.
I bought motor system complete with the mast at Flying Rodeo.
http://flyingrodeoefoil.com/motor-systems/
And where did you get the boat hatch? The size is great. Thanks
Everything made by myself. See my pictures.
Beautyfull! Are you using Samsung 25R? 12s15P, what is your ride time?
Approx. 50 minutes at an average speed of 22 kmh. Battery residual voltage 37V.
Hi.
How has your e-foil board been performing? Any problems, or planned improvements?
Thank you for posting. Your build is very inspiring.
i am actually satisfied with my setup. Now it’s winter break. My problem is that I don’t live right by the water. I have to drive at least 75 km to the next river. That’s the reason why I can’t ride E-Foil so often.
I may want to optimize my remote control. On the small OLED you can hardly see anything in the sun. There belongs an e-paper display. I also programmed quick and dirty.
Maybe I do something with the curve of throttle. Maybe a beeper for the warning that the battery is almost empty.
Hello
can you tell me what you put as “seal” for the access hatch , thank you.
thank you, it’s the seal around the hatch that I wanted to say!
