Very nice board. Is the whole insert PETG other than the bottom 3mm? Are they this kind of insert?
Thanks. Ive thought about using the sealed end ones.
Is it only the bottom layer that is 3mm fiberglass or is it around the sides as well?
Snowboard inserts I my goto for this type of application. Blind end and good pullout ressitance. M6
Fiberglass plate only at the bottom as reinforcement so that the inserts cannot be pulled out.
Thank you.
Do you know what hardness density is?
Also can you share the gasket slot dimensions?
I did not understand your question. What do you mean by dasket slots dimensions?
Epoxy resin with color pigments. But it wasn’t 100% tight. When laminating with vacuum injection I had a small problem with leaks.
Can you provide 3D files of the hinge inserts?
