Hi Matt, dimensions according to supplier datasheet are 167,5 x 64 x 11 cm (around 120 litters according to my calculations). Battery box is 43 x 50 x 9 cm
PVC core, two layers of fiberglass, the last one carbon fiber,
I just submitted an order with them for one sample board shipped to California, They told me 30 days lead time and promised good quality fingers crossed !!
After almost 3 months Just received the board!
The board itself is not bad but the lid and the finish is horrible. Hinges are crap and they literally drilled the screws with no boxes all hinges screws are weared out
The lid locks has not been installed and there is no stoppers for the locks in the box!
No rubber or oring on the lid!
Not sure how I am going to fix it thinking of embedding nuts for hinges and lock stoppers in the box but not sure how any suggestions?
You could use SS nut inserts.
You could drill a hole for the nut insert.
Use an Allen key on a drill to clear some foam under the laminate.
Fill the void with epoxy/microfiber mix
Then drill hole for the nut insert, and install
This looks like a great solution. Do you think it will hold that big lid without enforcing it with glassing? Ot what if I drill slightly bigger, place these and fill the gaps around the insert with epoxy ?
I would drill the right size hole for the insert. remove foam from under the laminate through this hole, and then fill with epoxy and microfiber mix.
Once the epoxy is set you redrill the hole for the insert.
They are self tapping so just install into the cured epoxy mix.
This way all you will see is the top of the self tapping insert. Tidy!
Maybe do a test to see what you think. If your not happy with the result you can always take it out glass something in.
Ive done it plenty of times and havnt had a failure yet. Try and get a good square inch of foam out to replace with epoxy.
