Very nice initiative. There is so much work for a solo man and in perpetual evolution that I have a suggestion. Why not using a mind map tool or a huge WIKI ? The writing could be parallel. A few people could help you out. You could create commits… in a pdf format if you like.
Best solutions have emerged like the forced flow watercooling through a pod nose inlet that cancels the pump need thus simplifying the wiring diagram thus the electric case (see @michion v2 board simplicity)
Then there is the matrix of options not easy to translate into a single pdf
1 - Board fully home-made or modified existing board ? Electric box: external plastic case or internal ? With or without hinged lid ?
2 - Electrical aspects
2.1 Wiring diagram: the minimum setup is: a motor, an ESC, a remote receiver, a battery and a protection system (fuse or ). A switch can be added to disconnect the battery during the transport. Possible sensors: temperature, water detection, etc
2.2 Wires and connectors tbc
Wire gauge AWG8 or AWG6, … 8mm connectors, AS150 (AS = Anti spark), XT90,
3 - Drive train,
3.1 motor: we have a wide choice of possibilities today
Inrunners : sold waterproof: Flying Rodeo or 6516x 100 and 120kv from Reacher / Flipsky / Maytech?
Outrunners : need DiY waterproofing : 80100 replaced by the 63100 (both APS) …6384 from FLIPSKY
3.2 propeller
3.2.1 Fixed or folding
3.2.2 DiY (3D printed, cast) or commercial (Flying Rodeo, Russian manufacturer, Solas, Chinese, new comers)
4 - ESC:
- 4.1 position: above the mast for simplified electric box (FliteB, Pegasus, Mantafoils, Waydoo One, …)
- 4.2 VESC or non VESC, max voltage 6, 10, 12 or 14s ? ESC with included BEC and anti spark solution
Lowcost Flycolor 60usd type, middle cost Flipsky 12s waterproof VESC, or SEAL 300A 14s non VESC, quality: Trampa 75/300 or TeamTriForce , high end MGM Compro 500usd+, …
- 4.3 ESC programming + modes (BDLC, FOC, ) + main brand user-guide links
_Non VESC
_VESC (motor-batt-ABS current, throttle calibration, ramping time, stator compensation, …)
Trouble shooting guide: symptoms/error code and solutions in a esc/motor use-case matrix (see @User1 10 - Trouble Shooting guide below )
As your esc/motor/wire length /connectors setup is unique, rerun a motor detection in suitable conditions : unloaded motor, so no lip seals; cable lengths in final configuration
non VESC: …
VESC: list of error codes with solutions, list of symptoms with solutions see ch 10 - Trouble Shooting guide below )
5 - Battery : commercial or DiY so far Li-Ion but Supernova should unveil their much awaited LTO cell based solution on the 2020/06/18 - probably 6s
6 - Hydrofoil front wing choice:
Commercial OR DiY : which surface, footprint and airfoil section?
Trend: new large surface high AR low thickness ratio (UniFoil / Windfoil wings / RL efoil wing / Gong Veloce 8%) should open a new way to low consumption drive trains using 6s batteries and low cost 6s ESC’s (see 8-Budget efoil here below).
7 - Remote control:
Commercial (MAYTECH, Waydoo (possibly August ) ) or DiY (Yahef, samisin, yours, new to come, …
8 - Budget efoil chapter (sub 1000USD) : a summary of the best practices
The 6s phylosophy by @JetboardCologne (60kg rider): set up for E Foil under 450usd :
Motor: waterproofed outrunner Flipsky 6384 120kv (avoid APS)
ESC: 6s 150A Flycolor boat: http://www.flycolor.net/index.php?c=category&id=149
Battery: Turnigy 6s 12Ah x2 in parallel = 6s 24Ah
DiY Propeller: 2 blades, 170mm (instead of 140-150mm in 12s with a 100-120kv inrunner)
Source @V_S 140mm increased to 170 and z-axis multiplied by 1.3
Amps and power drawn: take-off / flight: 80 A / 32 - 35A - Power: 1775 / 720W
Ride time: 35 - 40min
Speed: 25km/h
Front wing: Bic Techno windfoil 85cm span, 1300cm2 (Kerfoil design)
for heavier riders needing 120A to take-off who want to keep amps low:
a foot push rod along the mast to lower a flap to double the lift (at constant speed) and trigger a board take-off at 40A instead of 120A ? Should allow the use of a low cost 6s 60A ESC or 70A MK3 VESC ? The wing must be flat see Taaroa iUP thread.
9 - Buiilding and using your battery charger
10 - Future developments
IMU - Artificial Intelligence for which use ?
11 - Trouble Shooting guide
Motor-ESC use cases.
(1) User1 use-case VESC ESC figures for 65162 motor + Flipsky FSESC 200A VESC
(2) List of issues and solutions that have worked in the past
With Flipsky FSESC 200A waterproof
Reminder: as your esc/motor/wire length /connectors setup is unique, rerun a motor detection in suitable conditions : unloaded motor, so no lip seals; cable lengths in final configuration
Error 1 (Err1): ABS_OVER_CURRENT
Sol Err1.1: Abs Max current has to be a lot higher than motor current. Set Abs Max current to 200A and max motor current to 160A. Enable slow abs max current.
Sol Err1.2: install no_HW_limit driver if available
Sol Err1.3: check … increase
Error 2 (Err2): R0 is 1
Sol Err1.1: tbc
Issue 1 (Iss1): motor cogging and stalling during startup
Sol Iss1.1: check that motor is running on 3 phases instead of 2
Sol Iss1.2: Modify “Stator Saturation Compensation” from stock 0% to 10%, from 10% to 0%
12 - Advanced Trouble Shooting guide
Structure of a MotorConfig.xml configuration file
… and so on.
[Revisions]:
200621: added 9 - Buiilding and using your battery charger
