Q2: Will you make your efoil boards this way from now with tinted resins ?
Yes, because it’s more easy for a perfect finishes
Q3; Any picts of the different steps
no sorry
no sorry
Hi @jeffM , Congratulations on your work, I think many of us follow your progress.
I have 3 questions:
1.- The antenna that you take out of the mast together with the battery connectors is the FLIPSKY VX3 antenna, you place it under the carbon fiber throughout the deck, right?
2.- What is the TRAMPA nrf wireless dongle for? I get the impression that you program the VESC via USB. Is it to be able to configure after potting?
3.- Is the wiring between TRAP dongle / Usplit / FLIPSKY VX3 simple / intuitive?
If you answer, thank you very much, and if you do not see the message, thank you very much for all your work, it is very graphic and it is a great help.
Greetings
Hi
1-My first antenna was under the carbon, but it was too short
2- for program the VESC with my phone
3- yes it’s easy you have all the schematics with the usplit, but you need to redo some cables
I ask you for a hand i’m following jeff’s first wiring diagram i managed to make it work, but now it doesn’t work anymore. I’m lost! where I am wrong I hope it is a stupid mistake and that I have not done damage to the bms, where I am focusing the suspicions on the malfunction. When I start the bms it locks up when I turn it off you hear the kilovac release. I disconnected everything else in preventive mode. If you are patient, I also made a video.
https://youtu.be/y-ciJlE9zk0
Thanks I hope for some help
Well done amazing job !!! I going trough my project at the moment and I got couple of idea from your build !! Thanks
Why do connect red cable all the way from the last row of cells ?
Do you do the same of the black side ?
I m building a 12S10pm by divided in 2 so no bms for charging/discharging and I used my RC charger for 6S
Here some comments . By the way, your video is private, at least was not able to open.
" When I start the bms it locks up when I turn it off you hear the kilovac release". If wired correctly believe the kilovac should be activated by the main switch, disregarded of BMS function? Can see a auto fuse of 150 A. Is that Blue Sea or other quality brand? If not, its probably a crappy clone doing more harm than good… you already have another fuse according to the picture?
Hi @XSailor thanks for the reply,
The circuit Breaker E9 150 I bought it on amazon but I never doubted if it was a clone. I unlocked the video is to be heard rather than seen, sorry .
I am attaching another image, hopefully clearer.
@vib.dxb Thank you I’m glad you can help but it’s all thanks to @jeffM
tnks
Hi Andrea,
For help you on the troubleshooting, can you check the voltage here please :
and which battery and BMS you use
My bms is an ANT BMS h24S 100A, the battery pack is a 12S / 10P like your V3 project.
I forgot a premise, at the first installation everything worked, I disconnected to make the welds put aside and it doesn’t go anymore. I think I have replicated all the points but apparently not!
I checked the voltage as you asked, for each measurement by letter, I made a double measurement in the points you have rightly marked for me, the first without with the circuit connected up to the point the second with the circuit all connected, I also tried to replace the sbec with a new one and the SRD relays, it doesn’t change much. I suspect I messed with the bms app:
thank you
Is your battery 100% charged?
if yes you have a problem with the BMS
if not it may be the relay
Do you have the 5V on the SBEC ?
Do you have a smart ant bms? If so, install the app on your phone, log in and see how it works.
Hi guys, I’m still here to try and fix the problem.
I have charged the batteries still having problems
Going by exclusion I powered the circuit with the power supply and everything works fine.
So I focused on the drums as suggested by @jeffM and obviously on the bms.
I noticed that in the DIS MOS: I have the Pre-Charge Failure error.
Are there ways to best set this parameter in order to avoid the error?
@Anatoly will turn you the error screen on my smartphone
Thanks for your patience
I hope to be close to the solution.
In my opinion, you have a big voltage difference between the cell lines. 0.2A.Ideally, it should be 0.002A. Try using the app to enable balancing and leave it until it turns off itself.
Get the balancing right first , 0,2v as said is too high, 10p battery with what 0,2A balancing charging ? may take some time like 10-15H …
And maybe more than a day!
I have recently fitted and started using an ant bms, i am not claiming my settings are perfect but have successfully had several cycles now and happy to share these with you for ref.
This is my typ cell difference under charge.
I wanted to ask, if you use ANT bms, why such a complicated connection scheme? Kilowac, fuse, circuit breaker. Your bms already has all these features. The power button, discharge shutdown, short circuit protection. You are duplicating these functions. If you want to use the magnetic emergency stop button, disconnect the +5v power supply of the Bluetooth module.But I refused that, too. And to connect the Bluetooth module, you only need 5 wires +5,gnd,rx,tx,sin.Mot,bat are not needed.
Hi Anatoly,
You are correct this schematic version is for a power supply without BMS.
So with an ant BMS you can remove fuse/circuit breaker, (or you can keep them for more safety in case of BMS failure)
But personally I do not recommend removing the kilovac and only trusting a 5V cutoff to secure in the event of a fall.
it is necessary to cut off the power supply of ESC / VESC in case of fall
I already had an issue with my V1.
the power remained on the motor while the receiver had no more 5V
I watched my Efoil leave with no one on it
If I remember “pacificmeister” had the same issue
Experience that I do not wish on anyone
Yes, you’re probably right. There is a small chance that something will go wrong! I’ve been lucky so far! I refused the emergency stop button, it was so uncomfortable with it! Also, this cord was always confused! Having rolled back two seasons, there were no problems yet! But with cruise control was! After falling off the board, I didn’t reset the cruise, the Bluetooth connection was interrupted, but when I swam up to the board, the connection was restored and the board jumped out of the water! It’s dangerous! And now I’m used to riding without cruise control!
