ESC Flycolor X Cross HV3 settings on BlHeli 32
Telemetry Test of the Xcross BLHeli32 160A
Results
  • Voltage and temperature readings are quite accurate.
  • RPM measurements seem reliable, at least at lower RPMs. As I understand it, this RPM represents the actual motor speed measured by the ESC using back EMF.
  • Current readings only appeared above 3A, and the multiplier varied, making the readings unreliable.
  • Current consumption remained at zero throughout the test.
Setup
Connection: Connect the ESC TX pin to the UART RX pin of a microcontroller.
To increase the current, the motor was mounted on a mast, and pressure was applied using a cloth.
KISS esc protocol
Micropython code for esp32-c3 supermini board:
from machine import Pin, reset, ADC,UART
import machine
import time
import network
import socket
import _thread
import json
import struct
led = Pin(8, Pin.OUT)
led.on()
is_blinking = True
def led_turn_on():
    led.off()
def led_turn_off():
    led.on()
import time
uart = UART(115200, bits=8, parity=None, stop=1, rx=20, tx=21)
def update_crc8(crc, crc_seed):
    crc_u = crc ^ crc_seed
    for i in range(8):
        crc_u = (0x7 ^ (crc_u << 1)) if (crc_u & 0x80) else (crc_u << 1)
    return crc_u & 0xFF
def get_crc8(buf, buflen):
    crc = 0
    for i in range(buflen):
        crc = update_crc8(buf[i], crc)
    return crc
def parse_kiss_telemetry(data):
    if data and len(data) >= 10:
        try:
            # Verify CRC
            received_crc = data[9]
            calculated_crc = get_crc8(data[:9], 9)
            if received_crc != calculated_crc:
                print(f"CRC mismatch: received {received_crc}, calculated {calculated_crc}")
                return None
            temperature = data[0]  # °C
            voltage = (data[1] << 8 | data[2]) / 100.0  # Volts
            current = (data[3] << 8 | data[4]) / 100.0  # Amps
            consumption = (data[5] << 8 | data[6])  # mAh
            erpm = (data[7] << 8 | data[8]) * 100   # Electrical RPM
            rpm = erpm // (12//2)  # For a 12-pole motor
            return f"V:{voltage:06.2f} I:{current:06.1f} RPM:{rpm:06d} CON:{consumption:06d} T:{temperature:03d}C"
        except Exception as e:
            print(f"Error: {e}")
            return None
    return None
while True:
    led.value(not led.value())
    if uart.any():
        data = uart.read()
        telemetry = parse_kiss_telemetry(data)
        print(telemetry)
    time.sleep(1)
Makerbase 84100hp got only 6 mosfets , while XCross got 12 mosfets. Therefore more heat produced.
On the other it better handles cooling because mosfets soldered to the pcb and the pcb glued to the heatsink.
84200 got 12 mosfets.
Shunts of VESC add to the heating.
Mosfets used in Makerbase vesc 84100, 84200, 75100 and Sequre esc are HYG015N10NS1TA
Xcross 160A
Tested XCross 80A.
Added two capacitors. One capacitor on long leg - the leg melted.
Esc glued to aluminum plate. 12s 80A.
20s till esc temperature reached 130c.
Current protection to high.
This ESC can handle 53A max each phase (160A/3).
Who can help identify these parts on a xcross160? The brown ones are most likyly caps, but the others?
The black parts on the right are probably a resistor (small part) and a diode (bigger part).
yes, but what kind of diode.
Hi everyone,
For those who wish to use the reverse rotation with Maytech Remote,
Set your remote Throttle in Esk8
In the BLheli settings, go to Motor Direction and select Bi directional soft.
Now enter this values for the Throttle
Min 1040
Center 1475
Max 1960
Cheers
I noticed you have Stall protection off? How are you finding it with that setting. I’ve always had set to normal but do have a lot of issues with desync under high throttle.
I think currently I have it set to normal.
Anyway, I never had desync issues with blheli32 firmware. Which firmware, firmware version and which esc are you using?
Did you find the solution ? :slight_smile:
Nope, I am going to be testing my Sequre esc hopefully today. I have had this issue with all of my Flycolor X-cross ESCs, some worse than other but they all do it at some point. I’ve tried everything.
Could be that I am just right on the limit of what they can handle.
