I probably set the motor at max power and continued at max power above the water which likely caused the issue.
This is likely a consequence of inexperience. Pointing the board upwards is probably sufficient. I am experimenting. There’s very little information available on foil-assist techniques for those who don’t know how to foil yet
Ye, battery was full. No BMS, just fuse.
I doubt it’s an overheating issue for several reasons:
- The previous session was completely fine.
- The slowdown only began after a few startups and ollies, with rest periods in between.
- The ESC always feels cold to the touch (unlike the battery). Active cooling is a very effective type of cooling.
