They have a version with a 70165 motor (8800w peek) and one with 65161 motor (6000w peek). The smaller one is only $422.
Does anyone have any experience using these for e-foil?
Do you thing they would be suitable?
Maybe to heavy and long to be practical?
As I understand it “water jets” need a higher RPM compared to a standard propeller. Maybe it would be better to get the motor with a higher KV if using it with 13S. I think Flipsky offer the motors with custom KV.
For a Jet, you will need much more rotations, KV needs to be upped. Either by a gearbox or a higher KV motor. WIth the regular 120kV motor, there is not enough RPM.
Thanks for you input!
I have asked Flipsky for more details of the products. I also ask if it is possible to get them with a higer KV motor. I post here if I get a response from them.
Jonas
