@brycej Got a name? Concrete place doesn’t really nail it down. I live between Nederland and Black Hawk,
I got it from CES in winsdor. They had a few 3.3 inch high density in stock.
CES - Concrete Equipment & Supply LLC
(970) 667-5662
The foam is from ACH foam down in Denver. Not sure if you could get a piece of two there.
Most people are doing 12s 14s, and a few 16s. The worry at higher voltages it a shock hazard in the water. I got a 12s12p 30q and currently building a 14p10s pack.
Foil and motor, ESC, battery cells and a 100a BMS are here.
The foil is a nice piece. I’m impressed with the niash quality.
I eyeballed foam at lowes this weekend, wasn’t happy. I’ll give the concrete shops a shot today but otherwise I’m grabbing the pink extruded to get this going.
There’s just no way I can get the board built in 3-4 weeks unless I start shaping this week.
I’m doing a test print of this clamp right now.
Half is almost done, I’m optimisitic that it may just fit without mods.
For motivation, I’ve got the Naish mast in my office space to taunt me daily.
Booyah. The back fits the foil PERFECTLY.
Foam hunt continues. Slowed down from friggin food poisoning. bleh.
Anyhow, I got to thinking about water and batteries.
I’m seriously considering a Pelican 1495 laptop case to hold my cells.
I kinda like the idea of making a diy case using aluminum sides and glass or carbon sheet, but in the spirit of the quick build I’m digging the pelican case approach.
I admit, I am liking the idea of being able to easily lug the battery pack separately from the board too…
I’ve got foam - settled for 25psi XPS.
This thing is gonna be ugly.
Why? I’ve got 2 weeks to get it together due to various plans.
Meanwhile, my flipsky remote is still MIA. Grr.
Looks like the remote will show up soon!
I ordered fiberglass, epoxy, a pair of fin boxes and some other bits.
I think this board is gonna be a little boxy ugly due to time for shaping but I think I can get it together.
Decided to pursue a few propeller options.
- Print some with carbon reinforced PLA
- buy some cheap aluminums to mod and mess with (gonna drill out a yamaha prop)
Today I picked up a new planer, so I should be able to shape something decent. I am having a hard time getting a good quantity of polyurethane glue, so I finally just ordered it online. Seems like a bit of a shortage is happening there.
So the plan this weekend is to slice and glue up a 4 inch blank, then shape it down and get glass on it early next week. Biggest questions are down to how much to cutout for the battery and esc installs.
You can also “glue” the blanks with 1k foam, this way you can hotwire through the joint areas.
Given the fast build, I’m leaning toward just sawing the rough cut and then planing it down.
If I had a little more time I’d make up a hotwire rig - I have a suitable adjustable power supply but shaping on this first board has to happen this weekend or I’m hosed.
Keep it up @willo, we are exactly at the same point! lol
The hotwire is faster and will save you a lot of sanding.
I have done mine with just 3 pieces of plywood and an old transformer. I will send you a photo later today if you want.
Glue arrived, and now I’ve got a six inch blank curing in my garage.
Settled for low tech clamping - I put a bunch of truck tires on top of the foam.
My epoxy, glass and fin mounts showed so yeah I think I can do this.
If things go well I’m aiming to shape it this weekend and lay glass by mid week at the latest.
Today was car shopping day, but I did manage to kick off a prop print in carbon PLA on my ender 6 before I left. The 6 is fast, but I figured slow printing would save my nozzle a bit.
Anyhow, Right now I have a 3prop print of this going:
And I found another one that I’m going to print as well, using the same PLA… now if I could find the friggin thread I’d link it…
That one is shared by Michael Parker via google drive:
https://drive.google.com/file/d/1rG1Z83AsWAgs2CGrZ_4NfWc5G61rgQsa/view
Two props printed, kicked off another one so I have spares.
Parker’s design seems to have beefier blades, and uses quite a bit more material to create the base of the prop.
My Flipsky controller FINALLY arrived. It did not ship from the US as I expected, but it made it!
I slapped together a hot wire cutter and it worked just fine with a small amount of hanging on the glued sections. Works fine however.
I need to get a spring to add proper tension, so I guess I’ll wire it tomorrow after that.
I decided to use a body board I had as a vertical template, I’m liking the layout to far.
Realized that I should really add a guard to this thing. After hunting a bit, I found this one:
From this thread:
I think I have enough carbon fiber PLA left to finish it up.
I also realized that I could do a rifle case board as a backup plan for this trip. Hmmm.
OK, I’m hedging my bets. I’m still gonna try to get uglyboard together but I’m taking along a rifle case… just in case.
Uglyboard™ is shaped, took quite a while to cut the battery/controller pocket and the mount pocket with an oscillating tool. Didn’t have time to hunt down router bits.
I sort of murdered the mount pocket a bit, but heck with it. I cut a rectangle out for the mounts, test fit with the hydro mount attached, then put in a layer of 6oz glass, mounts, a foam filler in between (which is slightly short) then glassed over that. I’m going to get enough done that I can work on the board while I’m away from my shop.
Oh, sadly greenlight left out the orange resin pigment I ordered. It was gonna be sooooo orange.
I managed the base board pretty well and was thinking of just making a topper. However, now I’m gonna go with a $50 hatch from amazon. Looks like I’ll have to build out a mounting lip, but that shouldn’t be too bad if make up the lip out of foam and then glass the thing to the board.
Still UGLY but it’s gonna work!
I’m really only after like a couple months of usage on this board. I’m going to make a nicer build later this year.
Hello,
Any updates on your build? Any photos?
Would love to see it
