Super danke
24 characters
Super danke
24 characters
Do you think would the 100A version suffice for a 10800 130KV - Flier 400A esc build?
In theory it should, but with thinner wires it might heat up even moreā¦
I think I read here about at least one person who burnt one, so it might be safer to have some marginā¦
Which wires do I need to connect and what should I do with the other ones?
on the battery side, you can either connect them together or use only one of eachā¦
regarding the thinner black wire, itās meant to charge the capacitors to avoid sparks when you connect the battery, but Iām not using it as I have anti spark connectors.
finally the one with 3 colors goes to your receiver.
the motor side is straightforward⦠if it spins the wrong way, just swap 2 of the wires⦠.
Thanks what should i do with the other wires? + -? And can i program a current limit?
just isolate the ends to void shortcut and youāre okā¦
I donāt think you can limit current, but you can see a limit on the power in %⦠I didnāt play much with that yetā¦
Is the difference between the 100A and 150A versions simply the wire gauge (awg)? If I replaced the wires on the 100A model with 8AWG wire do you think it would suffice for the 130KV direct drive board?
Do i need the anti spark wires? Flier 400a
Iām not sure⦠may be the tracks on the board are stronger too ⦠you can try sending them a mail may be ā¦
if you donāt have antispark connectors, it might be better to connect the antispark first and then the main negative cable.
First test with the flier 400a went fine. I connected the cables fast and dirty (just for testing). I already noticed this thing has power. Mat! Whatās your start-up? speed mine is struggling to start-up.
Do you have any problem with the remote?
my board in a container right now so I canāt check, and I canāt put my hand on the screenshot I made⦠but I programmed my remote to ramp up kind of slowly, and and I think you can program a % power at startup or something like that⦠try playing with it.
also, you should try it in water⦠be ready to flood your bathroom, but it might behave differently when itās loadedā¦
Im sure I had my start up on autoā¦
Nope cheap China remote no problem.
Yeah I have the same one but I had problems with the throttle working intermittently. Also, itās not 100% waterproof so I suggest you put a condom over it for water testing. Mine stopped working after the first test day.
I opened it and did some hotglue over the bms of the battery(there was a uncoated conatct)
Mine works fine and Alexās his too
do you have a link for buying?
Is it this one?
