Hum, i know this Gulf board
Maybe.
i bought it from someone. Now I need to make some changes to it. I need to relaminate and make a change to the mast connection.
Hereâs my Instagram if somone interested:
https://www.instagram.com/p/CHXR2KqDEa9/?igshid=wjs41sqm8uoj
Someone?
20 character
20 characters and some more
Update:
Rebuilding the complete board. Ripped all components out and stated sanding. Unfortunately the paint is so viscous it always cloggs my sandpaper which makes it very annoying to sand.
Also stay tuned for my new waterproof remote v2 which is currently in a complete rework process. Custom pcb etc
If you had a heat gun (HeiĂluftpistole), that would help with paint stripping process.
Tried, didnât help at all. Just made bubbles and the couldnât be removed. But thanks for the tip
What brand of paint will u use to repaint the board. I was just looking at 2k PU acryl on www.lackmix.de it seems a high quality paint at affordable prices.
Funny that I didnât recove any notification at all. I use hp textiles epoxy and some carbon fiber. Will work on it after Christmas. Thanks. Am very busy with my remote design right now
Hi, my name is Chris⌠I am building eFoil with some props, but for safety i think, that the duct is important⌠Would you like to share the stl File for printing? After printing i would like to laminate it with carbon⌠IT WOULD BE NICE TO HEAR FROM YOUâŚ
So far I had to get my efoil done. I had to take my development a bit back for laminating and sanding my board. Fortunately Iâm finished now. Some small things like the silicone on the sides need to be adjusted, but the main thing is the remote. Iâm so happy how it turned out and how well it works. Unfortunately the waterproof 75200 has an production issue and needs to be sent back. I went back to my flier esc.
Best regards
Felix
The board looks really professional now. Before it was a real mess. Well done
where did you get your battery box?, also is that the finished FR remote?
Max004. Yes itâs my remote.
Your remote is awesome âŚ
Currently the remote is a protype material printed in sla. All protypes will be made in this material. The esc is the flipsky Vesc waterproof where the resistors are wrong. I will try to repair it one day.
Br
Hi Felix - could I ask, what firmware and ESC settings are you using for your Flier ESC to get it working with the low KV motor?
Best regards
Patrik
